07-16-2017
21:05
04:51
AlejandraFitbit
07-16-2017
21:05
04:51
AlejandraFitbit
Hi my name is Snunkhaem. I recently got a Fitbit Blaze last week but the the green light stop blinking and the heart rate do not display. What happen? Please help
Best AnswerYesterday my heart rate didn't register from noon to 3:00. So I shut off Bluetooth and put it back on and re paired the blaze and it seems to have worked. Give that a try.
It's great to welcome you @Snunkhaem. If your heart rate sensor is not longer illuminating, I recommend checking if your heart rate is "On" or "Auto", you can check this directly from your Blaze by swiping to settings and tap the heart rate option. Also, you can try to restart your Blaze.
Let me know the outcome. ![]()
