01-29-2017 05:08 - edited 01-29-2017 08:16
Followed instructions and paired device to my sony xperia X compact phone!! correct pin numbers etc .. play the music and Fitbit blaze stays connected for 5seconds and then says No connection!! re done set up 10 times and same happens everytime!! Grrrr Help..
Best Answer01-29-2017 05:19
01-29-2017 05:19
Hello @WayneRaney, not knowing what phone OS doesnt make it easy to help.
I find when the music control doesnt work, so does other Bluetooth input devices, such as keyboards and selfie sticks. For me i simply restart my phone, no big deal since an Android phone still needs to be restarted at least once a week or it will have performance issues. Currently i go 1-3 weeks between music control issues, and usually have them when i have failed to restart the phone recently.
Best Answer01-29-2017 07:52
01-29-2017 07:52
Best Answer01-29-2017 10:14
01-29-2017 10:14
I'm experiencing the same issue with a Sony experia xz. Works perfectly for my partners samsung galaxy s6, but I've tried everything to get it to work on my mine but with no joy. HELP!!!!
01-30-2017 06:19
01-30-2017 06:19
Must be the Sony because my fitbit connects to my kindle and other mobi phones and i can control the music from my fitbit when connected to those devices ... just the sony mobile refuses the music option.. connects ok to for notifications etc via bluetooth but hell it wont play ball for the music... Typical always something!!
02-11-2017 03:39
02-11-2017 03:39
Hello @WayneRaney and @Foxf, good to have you here in the Fitbit Community! Sony devices are limited in compatibility. My first recommendation is to review our list of compatible devices to make sure your phone model is capable to support all the features.
I too have a Xperia and is not capable to work with music control despite it syncs perfectly with my tracker.
It wont hurt to try the following steps, to address this issue:
If you see "Not connected" or "Connecting..." on your Blaze, test whether you're able to control music after trying each of these tips:
Hope this helps, see you around.
