07-12-2016 06:17
07-12-2016 06:17
I am training for a half marathon and hope Fitbit Blaze can help me train. When I go to exercise mode and use my phones GPS how accurate is distance traveled and pace? I have heard people say distance is off but I am not sure if that means when using GPS or not using GPS. For training purposes I need to make sure mileage and my pace are pretty accurate.... Thanks in advance.
Best Answer07-14-2016 11:37
07-14-2016 11:37
Hi, @TexasTommy! I've found that my GPS/walking distance is pretty spot on.
MakMak | Community Council
Best Answer07-14-2016 11:56
07-14-2016 11:56
@TexasTommy Fitbit has admitted you may experience distance errors, and they have been working on a fix for months. The real issue is that like heart rate, it appears to be inconsistent, so you may have excellent distance accuracy one day and bad the next day. Some folks on the forum have dug deeper, and run a phone app like MapMyRun at the same time as Blaze. The phone app will have correct distance, but Blaze is wrong. Again it doesn't happen for everyone, or every run, which makes it even more frustrating if you are training for a big event. Nothing is perfect, however for training I would recommend checking out a dedicated GPS running watch: http://www.dcrainmaker.com/2015/11/winter-sports-gadget-recommendations.html
07-14-2016 14:39
07-14-2016 14:39
Best Answer07-14-2016 15:37
07-14-2016 15:37
Thanks for the feedback @bbarrera! I'm guessing if it's an incosistent gremlin it's really difficult to track down the issue.
Best Answer07-14-2016 15:43
07-14-2016 15:43
the funny thing is that the early phone apps like Runkeeper had the same problem with mileage accuracy back in 2008-2009, and its long since resolved and forgotten. The HR accuracy issue is different, there are a few optical wrist and upper arm HRMs that are quite good, the rest of the pack isn't there yet. I do a lot of heart rate based interval training on the bike, where accuracy is important, and so I still use a chest strap.
Best Answer07-14-2016 22:17
07-14-2016 22:17
I've tried the Surge., connected Blaze, the Fitbit app, charity miles, mapmywalk, map my exersice, A fitness, the OS tracking of the phone, and Strava. Funny thing is that on a 10 mile walk, there is no agreement in distance.
Best Answer07-15-2016 07:52 - edited 07-15-2016 07:53
I'm seeing much better accuracy between my devices and AW connected GPS. The exception is Fitbit Blaze.
This year I have 141 bike rides and over 3100 miles. The majority of rides have been tracked with:
- Apple Watch using connected GPS (iPhone 5s)
- RideWithGPS app running on iPhone 5s
- Garmin Edge 520 GPS bike computer
The mileage for all the rides are within 1% of each other, and often within 0.5% of each other.
The Blaze mileage for rides is not always accurate. I'm not alone on Blaze mileage accuracy issue. On these forums there are widespread reports from walkers, runners, and bikers that mileage is not correct, from 5-10% and even a few reports of 20-30% inaccuracy. Apple Watch version of connected GPS is accurate, and mobile app like RideWithGPS is also within 1% of external bike computer GPS, so the Blaze accuracy issue is a Fitbit problem. Its been acknowledged months ago by Fitbit moderators, and reportedly being worked on.
Best Answer07-15-2016 08:46 - edited 07-15-2016 08:47
@TexasTommy wrote:I am training for a half marathon and hope Fitbit Blaze can help me train. When I go to exercise mode and use my phones GPS how accurate is distance traveled and pace? I have heard people say distance is off but I am not sure if that means when using GPS or not using GPS. For training purposes I need to make sure mileage and my pace are pretty accurate.... Thanks in advance.
I'm training for a few races this year (a very hilly 10-miler, and the Ragnar Reach the Beach relay, plus a few 5Ks) and do my training runs with a few folks with Fitbit Blaze and Fitbit Charge HR (both of which use a smart phone tethered GPS), and I use a Fitbit Surge. As a general rule we all end our runs (which typically range from ~5-miles to ~15-miles) with the reported distance showing within a tenth of a mile or two.
Upon occasion one or more of the trackers will get the results wrong, sometimes really wrong; I would say my Surge is the most accurate, but even then it can be wrong and the Blaze can be correct; you just never know.
07-17-2016 06:13
07-17-2016 06:13
Best Answer09-09-2016 11:13
09-09-2016 11:13
Best Answer09-09-2016 11:31
09-09-2016 11:31
@3StarMom wrote:
I am starting to think I should have invested in the Apple Watch.
I haven't seen any evidence which suggests the Apple Watch is any more accurate than the Blaze; do you have some infomation which says otherwise?
Best Answer09-09-2016 12:10
09-09-2016 12:10
Best Answer09-09-2016 13:07
09-09-2016 13:07
@shipo wrote:I haven't seen any evidence which suggests the Apple Watch is any more accurate than the Blaze; do you have some infomation which says otherwise?
Look up ^ I'll repeat it for you:
The mileage for all the rides are within 1% of each other, and often within 0.5% of each other. The Blaze mileage for rides is not always accurate, and someone took time to document that inaccurate Blaze mileage is suddenly accurate when sync'd to Strava.
I'm not saying its a universal problem, but it is happening.
Best Answer09-09-2016 15:16
09-09-2016 15:16
09-09-2016 17:38 - edited 09-09-2016 17:40
@bbarrera, your anecdotal evidence is pretty much irrelevant; I mean seriously, only 3,100 miles this year? Let me frame it for you, in the summer if 1974 I rode my bicycle 4,025 miles in 35 days, that and I've run in excess of 3,100 miles in a year twice since I turned 50, a heck of a lot rigorous than only 3,100 cycling miles in a year.
If you really want to get into it, I'll be happy to; the fact is, you seem to like to dump on my posts and it is time for you to stop.
09-10-2016 02:05
09-10-2016 02:05
Best Answer09-10-2016 02:31
09-10-2016 02:31
Which mode on the tracker do you use RT the run mode
Best Answer09-10-2016 05:58
09-10-2016 05:58
Me too. My brother has one and When him I and I walk there is a huge differnece between the fitbit and apple watch. We know we walk 8 miles cause we walk on trail that is 8 miles long. His watch will say he walked 8.01 miles. My fit will say I haven't even walked 7.5 miles. Yes I have set my stride also. The more I read baout fitbits issues the more I am leaning towards the apple watch. It sucks when you pay 200 bucks for something and it doesnt wok correctly.
