08-02-2017
10:50
04:58
AlejandraFitbit
08-02-2017
10:50
04:58
AlejandraFitbit
I have just bought my husband a Fitbit Blaze and am trying to set it up and it wants me to put a dongle in but it does not have one. Any ideas?
Welcome to the forums!
If you have windows 10 you do not need the Dongle. If not please contact support
Wendy | CA | Moto G6 Android
Best set up with your mobile device - download the fitbit app and it will walk you through set up.
Refurbished Dongles are available in the on line store should you ever want to sync with a PC, most everyone has a smart phone these days, sorry to confuse.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
It's great to welcome you @Bonner123, @WendyB and @wmchapman thanks for stopping by.
Our current trackers were made to be used with a computer with bluetooth or with your phone. As mentioned, if you have a computer with Windows 10 you can paired your tracker from there but my recommendation here is to set it up directly with a phone. Please take a look at our How do I set up my tracker? article, there you will be able to see the different options you have to paired your tracker.
Let me know the outcome. ![]()
