02-13-2018
13:16
03:47
AlejandraFitbit
02-13-2018
13:16
03:47
AlejandraFitbit
Cannot get replacement device to "set up" either on phone or laptop. Followed all instructions on website and phone with no success. Thoughts?
Best Answer02-13-2018 14:32 - edited 02-13-2018 14:34
Hello @Tommy_Hiebert let's choose one device to set it up. Since you say that it has failed. At what step did it fail at and was there an error message to forward on to here?
Have you looked at the troubleshooting guide yet?
Best Answer02-14-2018 03:49
02-14-2018 03:49
Great to see you around @Tommy_Hiebert and @Rich_Laue thanks for stopping by.
I would like to know if you keep having issues pairing your replacement tracker? If you do, I recommend restarting your Blaze and make sure you are doing the following from your Fitbit app to set it up:
Hope to hear from you soon. ![]()
