04-07-2018
04:27
04:44
AlejandraFitbit
04-07-2018
04:27
04:44
AlejandraFitbit
For some reason, the music that I am playing from my phone my Fitbit is not seeing that I am playing music. How do you have your Fitbit see you are playing music so that you can skip songs or pause songs?
04:45
05:07
04-09-2018
04:45
05:07
A warm welcome to the Community @chopper952.
If you want to use the music control on your Fitbit Blaze, I recommend taking a look at the How do I control music with my Fitbit device? article and follow the instructions provided there in order to use this feature.
I hope this helps, let me know the outcome. ![]()
04-12-2018 11:10
04-12-2018 11:10
it did not work for me even though I did everything it said
04:17
05:06
04-13-2018
04:17
05:06
Thanks for the update @chopper952. Can you please tell me which mobile device you have? In the meantime, as recommended in the article, double check that your phone is a compatible mobile device.
Hope to hear from you soon. ![]()
