03-26-2016 08:37
03-26-2016 08:37
Best Answer03-26-2016 08:41
03-26-2016 08:41
The battery icon on the Blaze's screen is animated when charging.. when fully charged the screen lits up and displays a full green battery icon. Possible to tap the screen while charging.
A full charge can take between 1 - 2 hours when the battery is low.
Best Answer03-28-2016 06:27 - edited 03-28-2016 06:28
Hello @tiedyejeff welcome to the Fitbit Community! 🙂 @SunsetRunner it's great to see you around
Charging your Blaze can take up to 2 hours. The battery life of the tracker depends on your interaction with it. I would like to share some tips to maximize the battery life of your Blaze.
Let me know if this helps!
It is health that is real wealth and not pieces of silver and gold! Share your story!
Best Answer04-03-2016 04:29
04-03-2016 04:29
Does 1-2 hours for recharging apply equally to Surge unit? Is there any way to determine length of battery life remaining as I cannot see any means to determine when running low?
Thank you
Colin
Best Answer04-03-2016 04:41
04-03-2016 04:41
@Colin44 , when you sync your Surge you will see a battery icon which will give you a very rough idea of the state of the battery. On your web based dashboard (not your app), under account --> notifications you can also set up to receive low battery emails from Fitbit.
How long your battery lasts deoends very much on usage. But you will do your Fitbit no harm at all to charge it little and often. Many people give it 15 minutes or so each day when they take it off to shower and they find that keeps them always topped up just enough. For best battery life it is good to avoid deep discharges, if possible.
I hope this helps! Welcome to the Community.
04-03-2016 06:56
04-03-2016 06:56
I charge mine every 2 or 3 days when the battery is around 50%.
The only battery-saving tip I employ is to disable quick view before I go to bed.
Best Answer04-03-2016 07:40
04-03-2016 07:40
I charge my Blaze when I'm showering. Pretty much the only time I take it off. Did this with my Charge HR as well. Battery was always fully or mostly fully charged.
04-03-2016 09:53
04-03-2016 09:53
Best Answer04-04-2016 05:49 - edited 04-04-2016 05:49
Welcome to the Fitbit Community @Colin44 and @TickledPinkTeri! 🙂 @Colin44 Charging your Surge completely takes 1 to 2 hours.You can see the battery level as suggested by @Julia_G on the Dashboard or on the tracker's display. As shown on the next image:
@Fosse66, @MikeS1971 thanks for sharing 😉
Happy stepping! 🙂
