Left side button not working
I have had my blaze for a little over a year and use it every day. Yesterday the left button stopped working so I can't back out of menus.
Any fix for this?
1 REPLY 1
It's great to have you here @Steeldefense! I would like you to restart your Blaze. Also, you may be able to remove dust or dirt by gently using a toothpick around the button. If this does not improve the button performance, you can try to clear debris using canned air. Hold the tracker at arm's length and spray once to loosen any dirt or dust that may have accumulated around the button.
Hope this helps!
