How do i manually change my steps? I do not sleep with my blaze on and left it on bc it takes forever to update the following day and i do not have time to wait in the morning. So last night it tracked 8k steps that i did not take.
It's great to see you around @kimk1986. It's weird to hear that your Blaze registered all those steps but don't worry, you can negate that extra information by manually logging the activity "Driving". To manually log this, you just need to do the following from a computer:
1. Go to the Activities page by clicking Log at the top of your dashboard, then click Activities.
2. Under Log Activities, click a common activity or search for your activity in the search box.
3. Select your activity from the search results. If the activity is not in our system, you have the option to create your own activity by clicking the Create custom activity text that will appear below the search field.
4. Enter the duration, distance (if applicable), and start time of your activity. You have the option to manually enter the number of calories burned here if you'd like to.
5. Click Log Activity. Your activity will now be visible and editable in the Logged Activities area.
I hope this helps, let me know how it goes. ![]()
