08-12-2016 14:26
08-12-2016 14:26
Best Answer08-12-2016 15:02
08-12-2016 15:02
@Reitz Can you post the specific activity you recorded? Also, what did you put as your running stride?
Best Answer08-12-2016 16:04
08-12-2016 16:04
Best Answer08-12-2016 16:32
08-12-2016 16:32
Best Answer08-12-2016 16:43
08-12-2016 16:43
@Reitz Well there's certainly the traditional way of calculating stride, but you can also use an online tool like this (which appears to be pretty accurate from what I can tell).
Take whatever steps you have for the activity combined with the distance you think is correct, and it should give you your stride length.
Best Answer08-12-2016 23:04 - edited 08-12-2016 23:06
@Reitz wrote:
I just ran 8 miles on treadmill but fitbit says I ran over 10.I know treadmill is pretty close 'cause it took 1 hour and 4 mins which is 8 min mile about what I normally do.I thought my stride length was good but guess not.I'm 6'3 and 205 anyone close to that know their stride length so I can compare??
Good luck, if you set stride for treadmill then Blaze will be wrong running outside without carrying a phone and using connected GPS.
Unfortunately Fitbit doesn't support foot pods, which long ago solved the mileage accuracy problem when running on a treadmill or any outdoor/indoor runs without GPS.
I'm 6' 1" and know my walking stride for different pacing, thats not going to help you because mine are for walking 13 min/mile, 14 min/mile and 15 min/mile.
08-12-2016 23:16
08-12-2016 23:16
If you take the steps the Blaze counted and the distance the treadmill says then an online calculator as @AndrewFitbit mentions will give the stride.
Distance divided by steps equal stride it's this simple.
Yes changing the speed your going will change your stride.
Best Answer08-12-2016 23:25 - edited 08-12-2016 23:25
treadmills need periodic calibration, which isn't done in most gyms, so you can't trust accuracy. If its important to you, for example if you do pace work, then get a foot pod.
M Go Blue!
