07-24-2016 04:32
07-24-2016 04:32
My Blaze has not synced since 12:50 yesterday, when I attempt to sync it gives error can not locate tracker. Well tracker happens to next to my phone so I go to fitbit.com and try with dongle still not fit my tracker. Blaze has by far become the worst product I have owned from Fitbit, not to mention the most expensive.
Best Answer07-24-2016 05:05
07-24-2016 05:05
Have you restarted all your devices?
The Blaze restart method is simplicity itself - press and hold the left button and bottom right button simultaneously until you see the fitbit logo.
07-24-2016 05:05
07-24-2016 05:05
07-24-2016 05:47
07-24-2016 05:47
Resolved the issue, many thanks.
Best Answer08-15-2016 09:10
08-15-2016 09:10
mine wont sync. I have restarted all items and nothing but battery getting low.
Best Answer08-15-2016 09:15
08-15-2016 09:15
Mine wont sysnc for the last 45 min
Best Answer08-19-2016 05:57
08-19-2016 05:57
Welcome to the Community @Peachykeen1171, @knober27 it's great to see you around and @jmattwood thanks for stopping by and for the recommendation. ![]()
@knober27 Have you tried the troubleshoot provided in the previous post? If you haven't, I recommend restarting your Blaze and after the restart process, try the syncing troubleshoot provided by @HelenaFitbit.
Let me know the outcome. ![]()
