My blaze is stuck
ANSWERED
This morning i had to re-charge, i turned off the fitbit and put it in the charger. Since then it is stuck on the fitbit logo.
28 REPLIES 28
Thank you so much!  I will try that
My Fitbit Blaze stuck on yesterday and wouldn't communicate with my iphone. I did the reset as described and all is well.
Thanks Alejandra... All good now and back to my routine with my Fitbit
It rebooted. Thanks!
I haven’t had any problems since it first got stuck.
Hi guys my blaze is stuck on the battery screen since 28th April. I’ve been waiting for the battery to die as the reboot isn’t working. It just lights up on the same battery screen for a second and then goes blank again. The green lights in the back are not flashing either so I’m stuck now. I have no way of knowing how long the charge is going to last for either because it won’t sync with my iPhone either. I’ve changed the clock face as suggested in this thread too but as expected it didn’t do anything due to no sync. Please help!
You to wait till it dies and it will take time. Then recharge it and try
and reboot. If nothing happens and your fitbit is in warranty you can get a
replacement which i did get. The same thing happened to my blaze a month
ago. But now they won't replace it any more and i had to trash it.
I have bought an ionic and hopping it would give me the same issues which
the blaze did.
Abishek
I habr followed all the suggestions and my fitbit blaze is still stuck and there is no green light. Please help.
I left the blaze on the loading screen until it ran out of battery. Then put it on the charger. When it turned back on it resets itself.
