Notification must be running for you to get calls.
What messaging app are you using?
Is the notification settings for messaging set for the right app?
Some text apps require view body to be enabled.
On the phone
Go to your sound an notifacation settings, swipe down to show on lock screen set it for yes.
Go to applications default make sure the right text app is set for default
Best AnswerThe only time other devices should interfere is if you sync your tracker through multiple deveces.. As in having a phone, pc, and an iPod, in this case the other devices need to be removed from the vicinity are there Bluetooth needs to be turned off.
It sounds like your up.
