09-06-2017 16:56
09-06-2017 16:56
One of my LED lights on the back of my Blaze is not on. I've tried the suggestion of turning the heart rate function in the app off sync and turn on and sync. Still only one of 2 lights. Was going to try a hard reset. What is the chances my Blaze is crapping out? It's about 19 months old. Thanks for any suggestions
09-07-2017 04:14
09-07-2017 04:14
A warm welcome to the Community @SunsetRunner, thanks for troubleshooting this by yourself.
If the heart rate sensor is not longer working, I recommend restarting your tracker one more time. Please confirm you did the following to restart it:
Hope to hear from you soon. ![]()
09-07-2017 04:23
09-07-2017 04:23
09-07-2017 04:29
09-07-2017
06:28
06:31
JuanJoFitbit
09-07-2017
06:28
06:31
JuanJoFitbit
Hello. I have done the same thing and both of my LED lights are not working as well. My heart rate hasn't been tracked all week. My fitbit is less than a year old.
Hello. I have reset my fitbit several times and the LED lights aren't working and my heart rate has been resting at 70 and isn't reading my heart rate and I have it turned to "on" instead of "auto". It is less than a year old.
Moderator edit: merged reply
Best Answer09-07-2017 07:08
09-07-2017 07:08
09-08-2017 04:08
09-08-2017 04:08
It's great to welcome you @ycompton08, thanks for troubleshooting this by yourself. As recommended to our friend, please keep an eye on your inbox for further instructions. @SunsetRunner I am glad to hear that you have been contacted by our support team and that you are working on your tracker.
Keep me posted about this. ![]()
Best Answer01-10-2018 20:00
01-10-2018 20:00
I seem to be having the same problem as described here. Only one green LED light working, I’ve tried the reset but no change. Any help appreciated. Thanks.
Best Answer02-07-2018 17:27
02-07-2018 17:27
Mine is doing the same! Tried the resets and still had no luck. The second led wont turn back on and the HR is not reading. Any other suggestions???
Best Answer07-06-2018 06:58
07-06-2018 06:58
Mine is experiencing the same problem. One light died after about 18 months of use. That seems to be about the lifespan of Charge 2s.
08-03-2018 06:11
08-03-2018 06:11
Hello,
I had 1 LED light quit working this weekend. It's causing my battery to drain quickly unless i turn the heart rate setting to OFF. It only reads my heart rate in the ON setting. So i followed your instructions to reset and it still isn't working. My fitbit is about 18 months old.
Lahrae
Best Answer08-03-2018 06:53
08-03-2018 06:53
Best Answer08-03-2018 08:15
08-03-2018 08:15
Best Answer11-20-2018 15:03
11-20-2018 15:03
I’ve also got the same problem. Started as a frozen screen. Then no heart tracking. Now only one led light. Use it everyday. I did crack the screen putting it into the charger. Probably my own problem now but if there’s any fix, I would appreciate ANY HELP
Best Answer04-05-2019 20:43
04-05-2019 20:43
Mine also just started to do the same. Only 1 Led is working even after doing a hard reset. From looking at the threads on here about the Blaze it seems the actual lifetime of the watch Is only 2 years before it starts to fall apart. Not good imo
Best Answer06-10-2019 10:25
06-10-2019 10:25
Agreed that average lifetime of the device is 2 years. Mine did the same and customer service refused to acknowledge this issue that many of us are having. Please DO NOT SUPPORT FITBIT any longer. Their devices are made to break after a certain time so you have to buy another for them to continue to make money. Please do NOT support this motto. These devices are not made to last. I am going to find another device that cares about their customers and QA in their products.
06-10-2019 12:44
06-10-2019 12:44
Replaced mine with an Apple Watch in December. Couldn’t be happier
07-29-2019 03:22
07-29-2019 03:22
Good morning.
I purchased my Fitbit Blaze in November 2018.
Up until a week ago, I had no issues with it at all and was enjoying all of its functions.
But now, my battery life has reduced from approx 3 days to about 5-6 hours. And also, only one of the lights at the back is now working.
I have read through this forum and have tried all of the suggestions.
Could you advise me of my next move please.
Thank you.
05-18-2020 21:01
05-18-2020 21:01
Hello, just a quick question did the company replace your fitbit? And if so, did they charge you anything?
05-18-2020 21:41
05-18-2020 21:41
