01-06-2018
10:05
09:28
FerdinandFitbit
01-06-2018
10:05
09:28
FerdinandFitbit
Hi,
I seem to have a problem connecting my Blaze to my Samsung S6 when I want to exercise either run or bike. I can maybe connect 1 out of 20 attempts but the signal looks very weak. All other info appears to be recording. Can anyone shed any light on the problem ?
Thanks
09:27
09:30
01-08-2018
09:27
09:30
Hey there @Vince_D. Welcome to the Fitbit Community Forums! 🙂
I would just like to make sure if this is when you're selecting the activity directly from your tracker.
If that is the case, make sure that along your route, there are not many tall buildings or trees as this could affect the GPS reception. Also, make sure that you are meeting the following requirements:
Hope you find this helpful and if you need anything else, be sure to let me know!
Best Answer04-18-2018 04:56
04-18-2018 04:56
hi ferdin, I've got the same problem dispite following your instructions.
any ideas
