06-10-2018
12:20
11:14
FerdinandFitbit
06-10-2018
12:20
11:14
FerdinandFitbit
I got a new phone and I keep receiving the error "blaze rejected your pairing request". I removed the pairing from my old phone but cannot get it to pair with the new one! Ugh
Hi there @mayme003! Good to see you in the Forums! 🙂
I'm sorry you're having problems setting up your Fitbit Blaze 😕
First, I'd like to know which is the new phone you're trying to pair your Blaze to... Have you verified that it is a compatible device? If not, you can do it here.
Second, after you've verified that your phone is compatible, I would like to make sure you're setting up your tracker from your the Fitbit app and not from the Bluetooth settings on your phone. For this, go to the Account section at the top right corner on the Fitbit app and select the option that says "Set up a new device". Follow the on-screen instructions and once you're done, your tracker should be syncing without a problem.
Let me know if you still need more help with this!
Hi, I just got a Blaz but it won't sync with my samsung Galaxy S9+. I see that my phone isn't on the list of compatible phone is there a way around this?
