02-28-2019
06:40
08:45
FerdinandFitbit
02-28-2019
06:40
08:45
FerdinandFitbit
I have Fitbit blaze and it is not charging from few days
any solution or any service centre details in India
Moderator edit: Updated title for clarity
Best Answer02-20-2020 13:39 - edited 06-09-2023 10:07
Hi there @Vanshp, welcome to the Community Forums. I'm sorry for the late response. Thanks for the details provided about your Blaze's battery behavior.
As per the description, it seems that it has insufficient power source. Where do you charge your tracker? Have you checked if by any chance the USB port or outlet is faulty? If you haven't done so, try a different port. A UL-certified wall charger will also work. Don't use a USB hub. You can find more detailed information in the help article: Why isn't my Fitbit device's battery charging?
Also, I'd like you to review the tips and recommendations provided in the article: Can I extend my Fitbit device's battery life?
As a friendly reminder, the following are some factors that have an impact on battery life and may cause your battery to drain more quickly:
If you still believe your battery is not lasting as long as expected, we’d like you to do a battery test to see how long your battery lasts after a full charge. Please do the following:
08:44
08:11
03-01-2019
08:44
08:11
Hi there @Balaji6794 , welcome to the Fitbit Community Forums! 🙂
I'm very sorry to hear that you're having problems charging your Fitbit Blaze. I'd like to help you out with this.
Have you tried different USB ports or outlets? If so, you can also try cleaning the contacts on your Blaze and the charger with some rubbing alcohol and a cotton swab and then, you can try again and see if this helps.
If you need anything else, feel free to let me know!
02-18-2020 03:39
02-18-2020 03:39
I am having the same issue, my blaze turns on for a second after I take it out of the charging dock but then it’s goes black with the Fitbit logo.Do you know how to fix it?
