Problems syncing
I have a lot of problems syncing my blaze to my account on my tablet.
5 REPLIES 5
Syncing can be quite troublesome and be caused by all sorts of issues. There's a troubleshooting guide here:
http://help.fitbit.com/articles/en_US/Help_article/I-can-t-sync-my-tracker/
Hello @Bigsid64 do you also sync through a phone?
If the phone is nearby you will need to disconect the Blaze from the phone before the tablet will be able to sync it. The easiest way to do this is by turning the phones BT off.
This is a limitation of BT amd not Fitbits
Hello @Bigsid64 welcome to the Fitbit Community! Did you follow the troubleshooting steps provided by @SteveH?  Also as @Rich_Laue mentioned if you receive call, text, or calendar notifications on your Fitbit tracker, your tracker has a Bluetooth "bond" with the mobile device that sends the notifications. This bond prevents the tracker from syncing with another mobile device or a computer. And turning off the Bluetooth of the other device eill help you sync.
Thanks for stopping by! 🙂
Retired ModeratorAngela | Community Moderator
It is health that is real wealth and not pieces of silver and gold! Share your story!
Thank you for your advice
Thanks for the advice
