Is anyone else disappointed with the quality of the Blaze? My time zone is wrong. It doesnt sync. I don't get notifications anymore. It didn't vibrate for notices. It is fully charged. My Blaze is about a year and one half old.. Twice before this I have had problems. I want something that works and doesn't require hours on the phone with a service person. What do you recommend?
Best AnswerNot disappointed with the blaze it worked fine for me although it did stop vibrating or displaying the notifications, but I'm thinking that is more a phone issue and not the actual watch as I reset my phone to factory defaults and that is where the trouble started as far as notifications were concerned, other than that it was working fine. Now I have the ionic and notifications are working fine.
As a suggestion I'd try resetting the bluetooth on the phone and re-pairing the watch to see if that fixes the notification issue as any phone update may have broken the connection, worth a shot.
Best Answer@Egarry have you checked your settings on the Blaze itself along with the notification status found on the music control page? Then check both the settings in the app and the phones notification center?
