01-08-2017
15:00
19:25
DavideFitbit
01-08-2017
15:00
19:25
DavideFitbit
Can i replace the battery?
Best Answer01-08-2017 10:52
01-08-2017 10:52
Battery life is supposed to last up to 5 days. Mine last 1 day if that. Ive had this thing for 2 months. Can i replace the battery?
Best Answer01-08-2017 10:54
01-08-2017 10:54
What Fitbit tracker do you have, @Bfallon80?
Best Answer01-08-2017 15:08
01-08-2017 15:08
Thanks, @Bfallon80. I moved your post to the Blaze Help Forum where it will be able to get more responses.
Best Answer01-08-2017 15:48
01-08-2017 15:48
@Bfallon80 Unfortunately you are not able to replace batteries in the Blaze. My Blaze's battery lasts me a good 4-5 days, and I have had it almost 1 year.
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
Best Answer01-08-2017 15:56
01-08-2017 15:56
01-08-2017 15:56
Best Answer01-08-2017 16:06
01-08-2017 16:06
@Bfallon80 If you have tried turning off all day sync, and some other options, and the battery is still not lasting, you can always contact support. They can look into it further for you.
Kelly | Oklahoma
