01-22-2018 19:46
01-22-2018 19:46
Fitibit have any repair centers?
My Bladge is not showing heart rate, upon trouble shooting found out that tracker is defective and out of warranty. It doesn’t make sense of just throwing a tracker which is $200.
Is this how Fitbit plans on selling more and more models?
07-21-2019 09:35
07-21-2019 09:35
I saw someone’s post above about https://www.joesge.com/ being a possible repair option. Did some looking on the internet to see if it was a scam but only found good reviews, so decided to give them a try. Super easy process. Thought it needed a new battery which their site estimated at $65. Sent it in (free prepaid label by Joes) and they diagnosed a different issue, only costing me $45. Sent it back for free. Super clear communication throughout the entire process. Got it back earlier this week and it is working like a charm again!! Battery is no longer draining in a few hours - it’s lasting several days again!! I’d highly recommend giving JoesGE a try - I will definitely use them again! Much cheaper than buying a new one!!
07-25-2019 14:40
07-25-2019 14:40
I’m having the same issue with mine as well. Trying see if you had any luck with soldering
Best Answer08-10-2019 05:36
08-10-2019 05:36
My fitbit screen has been damaged and it is only vibrating for messages. That means only the screen has gone.
Best Answer08-17-2019 08:23
08-17-2019 08:23
There are plenty of straps on ebay, I've purchased a few and they all seem OK.
Best Answer09-07-2019 11:38
09-07-2019 11:38
I believe I have the same issue with my Blaze. Have you had any luck repairing the charging ports?
Best Answer09-07-2019 13:13
09-07-2019 13:13
Hi, the watch was eventually regarded as being beyond repair by the owner and Fitbit asked for it to be returned to them, they paid for the shipping. After they tested it themselves they agreed to send a free replacement under the warranty. The watch was about 9 months old. That process took about 4 weeks. Hope this helps you.
Best Answer09-20-2019 21:38
09-20-2019 21:38
Hello, all efforts to boot my fitbit Alta hr proved abortive, please assist me. None to fix it on Nigeria. What do I do
Best Answer11-12-2019 20:58
11-12-2019 20:58
Very frustrated about this too! Spent over $200 for a versa only to go out within a yr, got a replacement n that too is out. They said they do no repair n was so upset coz we are not talking of a 20$ watch. That is very poor customer service and management. They should either make long lasting equipment or have better solutions. I sure ain't investing on a fitbit in the future and will spread word too coz I can't let loved ones waste their money like I did!
11-13-2019 15:31
11-13-2019 15:31
11-13-2019 15:49
11-13-2019 15:49
Best Answer11-13-2019 16:32
11-13-2019 16:32
16:45
12:07
JuanJoFitbit
11-14-2019
16:45
12:07
JuanJoFitbit
Go to Amazon and purchase a new Blaze watch band with a frame.
I just purchased a Blaze watch band with a frame from Amazon.
Moderator edit: merged reply
Best Answer11-19-2019 16:53
11-19-2019 16:53
They send only if it's under warranty.. I think it's 1 year from last pairing
Best Answer01-01-2020 14:11
01-01-2020 14:11
I've had my Versa for about a year and a half with no problem. It recently ran fully out of charge. When I put it on the charger it showed the 0% icon and then the Fitbit symbol. Charging didn't work so i bought a new charger. Nothing! When i contacted support found I'd need to pay to get support. Got so annoyed after what I spent in the first place I told them I'd just go buy an Apple watch!
01-01-2020 14:28
01-01-2020 14:28
For me I used only GPS feature .
Next time I will buy a cheaper watch and rely on phone for GPS.
I don't think fitbit will survive for long , the product is not worth money .
01-01-2020 17:00
01-01-2020 17:00
If the blaze has a battery inside of it, I'd be tempted to open it and see if can change it. It was a better design than the versa for me.
Anyone out there attempted to do this
Best Answer01-01-2020 17:53
01-01-2020 17:53
Hi @Dave1964 see Post #22 above where someone did send in their Blaze to a place that replaces batteries. The business also sells the battery if you feel capable of doing the work yourself.
Best Answer01-05-2020 13:57
01-05-2020 13:57
Best Answer01-06-2020 01:05
01-06-2020 01:05
I'm not sure what part of the world you are in but it seems that as time goes on more and more workshops are repairing Fitbit. Scroll back to the beginning of this community blog and you will see that other users have found repairers in the USA and maybe UK as well. Hope you find someone to do the repairs.
Best Answer01-06-2020 01:31
01-06-2020 01:31
