02-14-2018
01:19
05:13
FerdinandFitbit
02-14-2018
01:19
05:13
FerdinandFitbit
Hi there. I have recently gone from a Surge to a Blaze and my usual 5k running route has changed to a 5.5k route? Any ideas why a 2 week old watch would be so different in GPS tracking?
Welcome to the Community Forums @SteButler! 🙂
I'd like to know if when you're going out for your runs, you make sure that your tracker connects to your phone's GPS before starting your run... If not, this could be causing your tracker to report your distance based on the steps taken using your stride length instead of using GPS which should be more accurate.
Just in case, you can try to restart your tracker. You can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot.
Let me know if there's any change!
