10-25-2017 07:37
10-25-2017 07:37
My blaze is continually flickering between two screens so it thinks I'm swiping the screen all the time. Go to read the time and then it flicks so half the screen goes missing then returns straight away. Anyone know a cause or fix?
Best Answer10-25-2017 07:58
10-25-2017 07:58
First thing to try when a fitbit misbehaves is a restart using the following procedure:
https://help.fitbit.com/articles/en_US/Help_article/1186/
It does no harm and can sort out all sorts of issues. You might need to give it a few tries though as it's known to not always work.
Best Answer10-25-2017 09:18
10-25-2017 09:18
Try cleaning your screen @Liamclarke1 any lotiin or liquid will cause this to happen,
