12-27-2017
09:26
11:13
FerdinandFitbit
12-27-2017
09:26
11:13
FerdinandFitbit
I am deaf and rely on my Fitbit to wake me as I do not hear Alarms. My old flex woke me every time until the vibrator packed up. Ive had a new Blaze for Christmas and I can hardly feel the vibration in the daytime when it is time to take my medication and it certainly doesn’t wake me in the morning. Has anybody else had this problem or have any suggestions?
11:10
09:57
12-27-2017
11:10
09:57
Hi there @Croftysue. Great to see you in the Community Forums! 🙂
At the moment, the only recommendation I could give you would be to try to wear your tracker a little tighter while you sleep. If you wear it too loose, the tracker might not be in direct contact with you and you might not feel the vibration of the alarm very well but if you use it a little tighter, you should feel those vibrations a little easier.
Hope this helps and anything else you may need, I'm here to help!
Best AnswerI also received a Blaze for Christmas. I had a chargehr before and loved that feature. This vibration is so weak that I miss the alarms at least half the time. Fitbit is really good at listening to their customers - maybe you can improve this for your future customers.
I bought charge 2 weeks ago after my charge hr broke. I totally agree that the alarm vibration is too weak relative to charge hr. It should not be a complicated software adjustment. I just failed to understand why Fitbit does not want to improve this basic functionality which is perfect with my Fitbit HR.
Best AnswerTheir engineers spent a lot of time design software to track calories, step, sleep pattern, heart rates, etc. But they forgot most of the users also need the functionality of a basic watch instead of relying on our smart phones to set alarm, showing messages. This complain traced back in 2016 but the engineers are still unwilling to fix the issue. The moderator suggested us to keep the band tighter to feel the vibration. LOL! The same function performed well in an old model but cannot be done in an upgraded model. Hard to believe!
