05-21-2017 14:43
05-21-2017 14:43
I'm looking to get a blaze with the slim strap and frame. Does anyone know if I can then use different straps on this frame?
05-21-2017 23:36
05-21-2017 23:36
You can from what it appears. I have one and the bands have the metal pins to remove the band. I opted to purchase additional bands with frames to use. My frame does not allow for easy switch though as it appears to be a little to snug and it is difficult to switch back to it after I have worked out. AS I use the original band only to wear for dress and not to work out with.
05-22-2017 05:11
05-22-2017 05:11
A warm welcome to the Community @Victoriap12 and @Workoutteacher thanks for stopping by.
As you can see in the attached image, we have 3 different types of frames. You can check them out at our store.
At the store you can also check the different types of bands.
Catch you later.
