04-22-2016 17:28
04-22-2016 17:28
04-22-2016 18:11 - edited 04-26-2016 20:25
I'm wondering what type of exercise are we referring to, and are you going long enough.
Check your settings by clicking the track your exercise, then click the settings hear in the top right. Check the minimum time messed and that your exercise is enabled.
But why don't you want to use the exercising mode that is founded on the Blaze?
04-22-2016 18:47
04-22-2016 18:47
Best Answer04-25-2016 06:42
04-25-2016 06:42
Hello @JoAus and @Rich_Laue it's great to have you here! 😉 Are you still experiencing issues with SmartTrack recognizing your exercise? If you are have you tried to restart your tracker?
I'll be around if you have any questions.
It is health that is real wealth and not pieces of silver and gold! Share your story!
04-26-2016 18:38
04-26-2016 18:38
Best Answer04-28-2016 05:07
04-28-2016 05:07
Hello @Atlkajub welcome to the Fitbit Community! it's great to have you here 🙂 The activity recorded with SmartTrack will show up on your activity log after you sync your tracker. If the activity is not showing on your account I would recommend to restart your Blaze and test it.
Let me know if this helps! ![]()
05-16-2017 06:29
05-16-2017 06:29
My blaze no longer auto tracks my workouts (60min kickboxing) it tracks the steps and the calorie burn but it no longer logs it as exercise. I've tried restarting device closing app ect. Still does not auto log since last update.
Best Answer05-16-2017 08:45
05-16-2017 08:45
Im having the same issue.
Best Answer01-06-2018 00:01
01-06-2018 00:01
I'm having the same problem. Blaze has been sporadic logging exercise. I logs my steps, time, miles, steps just fine. I've tried restarting the Blaze, did not help
Best Answer03-06-2019 10:47
03-06-2019 10:47
I am having the same issue. My blaze is usually good at tracking my workouts, however it still has not logged a workout I completed on Monday. It was well over the 30min goal and for some reason will not sync to the app. I have tried logging out of the app and resetting my blaze but nothing has worked
03-06-2019 10:58
03-06-2019 10:58
May I ask what type of exercise where you doing and what type of exercise is it usually reported as?
03-07-2019 19:43
03-07-2019 19:43
I was doing a mix of weights and cardio. It usually comes in as either an aerobic workout or weights and a walk/run
03-12-2019 07:07
03-12-2019 07:07
Nice to see that you're digging into the Fitbit Forums @sfernandocole, let me give you a warm Welcome to our Community. Thank you for restart your Blaze.
Many thanks for your assistance @Rich_Laue.
There are several ways to track your workouts and activities with your Fitbit device. I would like to know how do you do exactly. Is it with the Exercise App or SmartTrack?
Note that trying with more than one way could make you lost some data.
I'll be looking forward to your new comments!![]()
Best Answer03-14-2019 05:51
03-14-2019 05:51
So typically it will track if automatically because of the active minutes and heart rate. But it has stopped doing that. Whenever I select weights within the blaze it does track it, but if I take a walk after lately it has not been tracking it even though it usually does. I have also tried manually entering the workouts but then it adds active minutes to my day which is not correct
Best Answer03-14-2019 08:32
03-14-2019 08:32
Like weights @sfernandocole have you tried using the manual mode see called walk?
03-14-2019 12:24
03-14-2019 12:24
Well no because 1) I’m usually on a treadmill and 2) historically whether I’m on a treadmill or outside my Fitbit always tracks it. And now suddenly it’s not
Best Answer03-14-2019 13:25
03-14-2019 13:25
treadmill is not an auto detectable exercise, and without manually starting it should not be tracked, if it is being tracked as some type of exercise, other than treadmill, there may be an issue with the Blaze and I suggest a restart it a power off/on.
03-14-2019 14:02 - edited 03-14-2019 18:35
Okay... it has tracked it in the past 🤔 so I think it does auto track it as exercise. And there’s been no issue with my blaze till now. So thank you anyways.
Best Answer03-14-2019 23:43
03-14-2019 23:43
True @sfernandocole I want trying to be helpful, but to get an answer that could be helpful in figuring out what is happening.
You say the Blaze would auto detect a treadmill run, every though it's had no logic to do this. Did the restart of the Blaze h lp?
03-15-2019 07:38
03-15-2019 07:38
Right. It would auto detect the treadmill as a walk or run, I believe due to my heart rate. It all counted towards active minutes as well. And what's happening now is it will track my active minutes but doesn't classify/log it as a work out.
The restart did not help.
