02-05-2018 12:54
02-05-2018 12:54
The pin keeps coming out on my blaze.Nearly lost the watch ,anyone with the same issue.
Best Answer02-05-2018 12:58
02-05-2018 12:58
Hi, @Leerichards, I had that problem the first few times I tried my Blaze. Basically that is likely to mean that you haven't got the pins in quite right. You should be able to tug on the straps and they shouldn't move at all. I would definitely not advise going out until you are sure that the Blaze band is properly attached, or it may fall out. If you can tug it, and it comes free, it is not in right.
10-29-2018 10:46
10-29-2018 10:46
I have the same problem with my Icon. I think the band stretches over time as I was having trouble getting it to stay in the notches. Now it has fallen out completely and I can't find a way to replace it. I'm going to contact Fitbit.
