It's great to see you around @Lyndsay9805. If your tracker is not swiping, I recommend Restarting your Blaze. After the restart process test your tracker.
I hope this helps, let me know the outcome. ![]()
Best AnswerI have the same issue. If I restart my blaze it will work for about 5 minutes after the reboot, then I have to reboot it again to use the swipe. Do i need to do a product exchange?
Best Answer@jtrenerry i don't see how anyone from this awesome community of fitbit users will be able to help you, i suggest contacting fitbit and have them look at the back end of your tracker.
Have you tried, when it works, swiping over to settings and doing a shutdown?
