01-26-2020
21:05
11:39
RicardoFitbit
01-26-2020
21:05
11:39
RicardoFitbit
My Blaze isn't syncing. I last synced on 22nd,before that on the 9th, prior to that it hadn't synced since late November. Why isn't My Blaze Syncing?
11:38
16:35
01-27-2020
11:38
16:35
Hello @bmanzie, welcome to the Community Forums!
Thanks for bringing this to my attention. To better assist you, can you please let me know which mobile device are you using? If you haven't already done so, I recommend you to check how the syncing procedure works here and see if there's a missing requirement on your mobile device that's preventing the syncing procedure to be completed.
Then, you can move forward to the troubleshooting steps that are specified on: Why won't my Fitbit device sync? and let me know how it goes.
Keep me posted, I'll be around if you need anything else.
I have a similar problem. My tracker last successful sync was 2nd of Jan 2020. I already had to stop using a mobile app and moved to Windows 10 in order to sync.
Looking at your link "how the syncing procedure works" I saw that the Windows app has a "Classic Mode" connection type, which is USB! That was a breakthrough.
I can now sync through USB but not via Bluetooth.
For Bluetooth I've looked at this forum and tried most things and nothing works for me:
* stop/start the tracker (more than 20 times)
* pair/unpair from WIndows 10 Bluetooth manager
* remove the device from my profile and re-register
++ during the re-registration, the Fitbit app successfully gets the tracker to display a 4 digit pin
-- but ... it also detects that the setup is tacking too long
-- registration always fails (bluetooth connection issue)
* reset the device - pressing left button + right/bottom together (10 sec) till logo shows on screen, then let go
-- no difference
I there are any other manipulations we can try to get Bluetooth to work this would be helpful to know about.
Many thanks
