01-24-2017 06:46
01-24-2017 06:46
My blaze will not sync unless I restart my galaxy s6. I have followed all of the troubleshooting steps and the only way I can get it to sync is to restart my phone. I have to do this every day! I would like to know if this is an issue with my phone or with my blaze. Thank you.
Best Answer01-24-2017 08:30
01-24-2017 08:30
Did you recently apply an Android security update? The last one caused that to start happening to me.
Best Answer01-24-2017 10:03
01-24-2017 10:03
It looks like my latest security update was in december, and that's about when this started happening.
Best Answer01-24-2017 10:32
01-24-2017 10:32
I'm having this issue as well. Very frustrating. I have to fiddle with it constantly to get it to sync. Sometimes restarting my phone fixes it, sometimes restarting bluetooth fixes it, and sometimes nothing fixes it and I wait days for it to work. Really frustrated with it.
Best Answer01-25-2017 04:01
01-25-2017 04:01
Great to welcome you @SunsetRunner, @Kstosic and @SunsetRunner thanks for stopping by.
I would like to know if you keep having problems syncing your trackers? If you do, I recommend following the instructions provided in the Having trouble syncing? post. After these steps your tracker should work without an inconvenience.
I hope this helps, let me know the outcome. ![]()
Best Answer01-25-2017 06:22
01-25-2017 06:22
