01-15-2018
13:11
06:10
FerdinandFitbit
01-15-2018
13:11
06:10
FerdinandFitbit
Hello
Fit blaze screen not responding. Only screen that comes up is the following. Looks like a themoustat in a triangle, orange in colour. .
Thanks
09-10-2019 17:21
09-10-2019 17:21
Great guys!
Well, it seems heart rate monitor is guilty for most problems stated here in community forum.
I also experienced freezing touch screen and short battery life. Every time disconnecting heart rate monitor for a short period helped get rid of the problem(s).
For now I permanently disconnected heart rate monitor on my watch because I don't need it very much and everything else works just fine.
09-10-2019 17:28
09-10-2019 17:28
I did that but it seemed like it wouldn't charge after that.
09-11-2019 09:32
09-11-2019 09:32
Charging connector is not connected to the heart rate monitor. I can charge my watch without any problem.
12-07-2019 12:00
12-07-2019 12:00
Hello,
I have been having the same issue with my blaze. Tried to follow all the instructions on here and others to reset/restart as well as change conditions for watch but no luck.
Can you please advice on what to do next?
Thanks
12-12-2019 08:17
12-12-2019 08:17
Regarding the orange triangle appearing on my Blaze, I have the same issue. Tried to reset it a number of times and the Fitbit icon does not appear. Still at the orange triangle temp icon.
12-13-2019 01:49
12-13-2019 01:49
Hi there. I am experiencing this issue. I put my blaze on charge, then noticed it had the temperature emblem in orange. I took it off of charge but now it will just show that the battery is almost dead or either the Fitbit emblem. Please help!
07-08-2020 14:36
07-08-2020 14:36
My Blaze has lasted for years and all sorts of conditions. Unfortunately I can’t recover or restart or relink to Bluetooth — It just won’t function. Will Fitbit reach out to my email with a solution? I’d like to keep with Fitbit
07-08-2020 17:09
07-08-2020 17:09
07-09-2020 21:47
07-09-2020 21:47
07-15-2020 17:51
07-15-2020 17:51
Hello
please don’t send all people on support ticket. We all go here from google search. For the same problem it will be more useful if you tell us here when happened with this symbol
thanks
07-15-2020 20:48
07-15-2020 20:48
07-21-2020 04:23
07-21-2020 04:23
Same here...super disappointed with Fitbit and will never purchase another Fitbit device.
07-26-2020 21:46
07-26-2020 21:46
Ola,
I'm experiencing the same issue.
Is this plannwd obscolescence for pushing us to buy a new Fitbit?
Thank you for your help!
08-27-2020 13:18
08-27-2020 13:18
fit bit blaze has triangle screen with thermometer and will not reset.
09-02-2020 21:38
09-02-2020 21:38
I have the same problem.
Temperature symbol
09-03-2020 09:29
09-03-2020 09:29
I’ve been having the same issue as well. I’ve tried everything and nothing has worked. I also had issues with the battery automatically going dead within minutes of fully charging it. Please help!
09-03-2020 11:06
09-03-2020 11:06
09-09-2020 11:09
09-09-2020 11:09
I am having issues with temperature symbol also. I tried everything suggested but no luck in getting it to work again. Is there any fix for this or no?
09-09-2020 11:37
09-09-2020 11:37
09-09-2020 12:58
09-09-2020 12:58
i know have the Flex 2 but I also wouldn't by another Fitbit smartwatch.
