03-10-2017
01:06
06:09
AlejandraFitbit
03-10-2017
01:06
06:09
AlejandraFitbit
Blaze not syncing with app and didn't track sleep. Can someone help and I restarted both?
Moderator edit: Subject and format
03-10-2017 01:21
03-10-2017 01:21
i got it the apps just werent working right but i got them going ty
03-10-2017 01:21
03-10-2017 01:21
03-13-2017 06:09
03-13-2017 06:09
It's great to see you around @NikkiiBaby and I am glad to hear that your inconvenience has been resolved. If you need anything else do not hesitate in posting it.
Catch you later.
03-27-2017 05:10
03-27-2017 05:10
Hi, My blaze is not completely syncing with my dashboard, my sleep do not register at all even though I wear my blaze all night, also my activities do not sync on a regular basis, it is a day behind which I find it difficult to follow my progress on a daily basis. I'm not sure how you solved this issue, can you help me please?
Thank you 🙂
06-21-2017 08:28
06-21-2017 08:28
Track is not found
06-22-2017 04:17 - edited 06-22-2017 04:17
It's great to welcome you @Vonnicksrgmail and @Hygie great to see you around. If your trackers are not syncing, I recommend following the instructions provided in the Having trouble syncing? post. After these steps your trackers should sync properly.
Let me know the outcome.
