05-30-2016 06:40
05-30-2016 06:40
Best Answer05-30-2016 07:23
05-30-2016 07:23
To update alarms through a computer will require a sync. You say there is no wireless Internet, does the computer have a wired internet could you install the Fitbit software and a dongle? N9w if it is a Win10 computer ypu cam sync through the chargong cable., or many tomes through the computers bilt in BT
Best Answer05-30-2016 07:50
05-30-2016 07:50
Best Answer05-30-2016 08:44
05-30-2016 08:44
The Blaze doesnt come with a dongle, as for being able to set alarms on the Blaze, are see whats going on, you would need to be able to sync. This will require comunication between the Blaze and Fitbit. The Blaze will save 30 days of data, so if you can sync through the phone once or twice a month, the steps will be recorded.
Best Answer05-30-2016 14:10
05-30-2016 14:10
Best Answer05-30-2016 14:21
05-30-2016 14:21
Currently your fitbit will record your activity and save it for up to 30 days. There is a request in the feature request forum for off-line syncing, and have the data stored locally.
There also is a request to be able to set the alarm off-line. Then another request to be able to setup alarms right on the Blaze, something i thought would have been a no brainer.
