06-06-2017
08:39
19:57
DavideFitbit
06-06-2017
08:39
19:57
DavideFitbit
I have tried shutting down my fit bit blaze at least 20 times, it will not stop vibrating and has a dead battery now. When I put on the charger it starts vibrating again....
Best Answer06-06-2017 09:49
06-06-2017 09:49
First step -
On a computer go to https://www.fitbit.com/settings/profile
click on the icon of your Blaze.
the first line is Alarms - does it say "no alarms set" ?
If not choose, "no alarms set"
Now put your Blaze back in the charger and press and swipe down on your mobile fit bit app screen to force a sync - does the alert end?
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
Best Answer06-06-2017 09:58 - edited 06-06-2017 10:00
Next step if still vibrating:
remove Blaze from its charge cage, press (and hold) the left button and bottom right button together and hold for a count of 30. Let go, after a final shimmy, does the vibration stop and tracker turn off?
Turn back on by pressing left button, is it quiet or vibrating?
If vibrating, Final step
Go back to https://www.fitbit.com/settings/profile on a computer, log in
down at the bottom click "Remove this Blaze from your account"
If no, then contact customer service and let them know what you have tried since it appears to be your Blaze.
If yes, on your mobile, re-pair your Blaze to your account 🙂
WmChapman | TX
