02-02-2018 00:10
02-02-2018 00:10
My Fitbit blaze won’t turn on. Even when it’s been on charge for hours... what do i do?
Best Answer02-02-2018 01:57
02-02-2018 01:57
Hi, @Martino1, if you are charging it via a computer, try a wall charger (your mobile/ cell phone charger should be fine as long as it is UL/CE certified), and give it a couple of hours even if it doesn't seem to be charging. Once it has has at least two hours on a wall charger, try a restart: hold the left and bottom right button for 10-15 seconds. If nothing happens, repeat this 2 or 3 times more and hold it a little longer.
Hopefully that will bring it back to life. If it still doesn't work, get in touch with Fitbit Customer Support on contact.fitbit.com
02-02-2018 01:57
02-02-2018 01:57
02-02-2018 04:37
02-02-2018 04:37
Mine did the same thing. I just bought a new Blaze with a new charger. The problem may be the charger not the Blaze. Both the old and new Blaze charged with a new charger, you can buy the charger by itself before investing in a new Blaze.
Best Answer02-02-2018 04:45
02-02-2018 04:45
Best Answer02-02-2018 13:19
02-02-2018 13:19
Hi, @Martino1, I am very glad that the restart worked for you! Did you need to change to a wall charger?
02-02-2018 14:15
02-02-2018 14:15
heres what you can try you hold all 3 buttons on the blaze and wait until it shows the fitbit logo if it will work. Tell me if it works or doesn't
wrote:My Fitbit blaze won’t turn on. Even when it’s been on charge for hours... what do i do?
Best Answer02-02-2018 14:56
02-02-2018 17:23
02-02-2018 17:23
Best Answer02-03-2018 05:27
02-03-2018 05:27
Best Answer02-03-2018 05:28
02-03-2018 05:28
Best Answer02-03-2018 15:04
02-03-2018 15:04
