Hello and welcome to the forums @dyam
Battery life varies from one person to another and it depends on how often you're syncing or checking your stats. I find with my Blaze that it can go about four days before I need to recharge it. With mine, it's just keeping time, heart rate and the stats. I don't have texts, notifications or calls going to the Blaze. When I did, the battery needed to be charged every two to three days, depending on how many notifications, calls or text were received.
I found it easier to charge the device every other day, so it stays charged. It never takes more than two hours to charge it when it's low.
If you need anything else, we're here for you.
Keep on stepping!
@dyam forgot to say that the battery is inside the tracker part, which is called the pebble. It is covered by the 365 day warranty (in the U.S.A.) and if you purchased an extended warranty, it could be longer.
It should last 4-5 days with all features enabled - heart rate, all-day sync, a dozen notifications a day, etc. A bit less if you track workouts, get tons of notifications or look at the screen a lot, of course.
Charge it at least for 2 hours and ignore it when it says it's full. The battery calibration software seems to get confused easily.
