Well i thought i`d upgrade from my charge 2....i bought a fitbit blaze off ebay,if i had seen the many posts concerning the poor battery life would of swerved the blaze...my blaze last just over a day,so much for the 5 days its ment to last...just wondering what the shortest time it takes to rinse the battery?
Best Answer@fazer600 why not see if you can return the Blaze to the eBay seller. You have no idea of how that Fitbit was treated, if there was abuse or if it had battery problems before you bought it.
My Blaze held a charge for four days or more before I needed to charge it. I didn't use all the notifications or alarms, so it lasted pretty well. Never had to charge it more than two hours to get it to full from a low battery.
I have since spoke to the seller,he said i could return it,however i`m going to charge it again and alter the clock face and also the brightness...thats all i can do as i did not have notifications set up...hoping this solves the problem.
Thanks for your advise
regards neil
