06-12-2016 06:14
06-12-2016 06:14
Just got a new Blaze yesterday. I have a Charge HR which is currently connected to my app. When I try to install the new Blaze, it gets stuck on the setup screen (once I tap Set Up Your Fitbit Blaze). I've tried force quitting, restarting my phone, turning bluetooth on and off during setup (charge hr far away when on) and contacting Fitbit support on Twitter. They recommended I try another support channel, as their suggestions were things I had already tried. They also said it has nothing to do with having another Fitbit installed, as others have suggested.
Anyone have this issue and know how I can fix it? Calling isn't an option right now, as my mobile phone is my only phone, and I can't exactly set up from my phone while talking to them.
10-13-2016 22:00
10-13-2016 22:00
Best Answer10-14-2016 10:38
10-14-2016 10:38
Best Answer10-26-2016 11:38
10-26-2016 11:38
i just wasted 2 days trying to set up my blaze on my laptop. here's how i finally got it to work: my laptop did not come with windows 10, i only just recently installed windows 10. so the laptop wasn't recognizing the download and my blaze was stuck on fitbit.com/setup. if your pc didn't come with windows 10, DO NOT PRESS THE PINK DOWNLOAD BUTTON!! instead, click the little 'PC' that's below the pink download button and go from there. it takes a few minutes longer, but that is what worked for me. i hope this helps someone. fitbit has lousy support!!
Best Answer12-30-2016 10:21
12-30-2016 10:21
That worked! Thank you!
Best Answer02-18-2017 20:22
02-18-2017 20:22
I tried deleting the fitbit app and downloaded again. My phone can see the Blaze, but can't communicate with it. I tried turning blue tooth off and on again. It didn't work.
Best Answer02-18-2017 20:35
02-18-2017 20:35
@CherryPicker are you trying to setup your Blaze?
Is it the Fitbit app that can't comunicate?
Best Answer05-26-2017 17:46
05-26-2017 17:46
I'm having problem with my blaze, I have logged in and everything I click the profile and click on the "set up a device" then I click blaze, I enter the number on the display, but nothing happens after that. It keeps on saying connecting to Fitbit yet the thing is my messages actually do come in it's just the time is different and it also says the date is Thursday, Dec 1 instead of today's date which is Friday, May 26. Can someone please help.
Best Answer04-12-2018 11:42
04-12-2018 11:42
I am having no luck at all with setting up my Blaze tracker. I get to the updating bit and then it stops !!!!!!!! Very frustrating !!!!!! Any help would be appreciated !!!!!!
Best Answer04-12-2018 12:53
04-12-2018 12:53
What stops @Honeymonster? Did the update finish?
Best Answer03-22-2019 04:54
03-22-2019 04:54
Worked immediately! Thanks.
