05-16-2019
02:22
16:10
05-16-2019
02:22
16:10
Can you please add Xiaomi a2 lite to the compatible devices. I really to find out that my new phone does not connect with my fitbit
05-17-2019 12:37
05-17-2019 12:37
Hello! Welcome aboard @Marijke53, let me give you a hand with your Charge 2 device.
Let me share with you that Fitbit is always working and testing on several mobile devices to add and verify their compatibility with our products and services. As it turns out and just as you stated on your post, the Xiaomi A2 lite is not listed on our compatible devices list, therefore, you can experience certain connection difficulties. That said, because my intention is for you to enjoy the Fitbit experience in full, I recommend you to use your Charge 2 device with a compatible mobile device or a computer.
I’ll recommend to check this post which will explain you to download our Fitbit app in your computer as an alternate syncing option.
I’ll be around if you need anything else.
05-17-2019 12:46
05-17-2019 12:46
05-20-2019 14:56 - edited 05-20-2019 14:56
You're welcome @Marijke53 thanks for your reply and update. Pardon me for the delay in responding.
I'm glad to know that you are able to sync your Charge 2 with your computer. Please note that due to the compatibility situation of your Fitbit and your mobile device, you may encounter difficulties with the GPS connection during your activities. Please try with a different mobile device that is listed as compatible and let me know if you still experience difficulties.
Looking forward to your reply. Let me know if you have any additional questions.
09-02-2019 04:40
09-02-2019 04:40
Me and my wife are experiencing the same issues as the Original Post here.
It's dubious and suspicious how so many people are having the same problems since about the same time. Fitbit should perhaps admit planned obsolescence here... To this day, no solution, things that worked before, stops working at the same instance updates are released.
09-10-2019
19:19
09:38
09-10-2019
19:19
09:38
Thanks for your post @marlonZA, sorry for the delay in responding.
Thank you for taking the time to share your thoughts and personal experience with us, I totally understand that you're frustrated with this. If you're using a non-compatible device, please review and take in consideration the information that was shared on my previous post. Thanks for your feedback.
01-07-2023 08:42
01-07-2023 08:42
Kindly advise on the new process on how to sync the Fitbit Charge 2 HR with a Xiaomi A2 Lite now that the windows app has been decomissioned.
