How to reset time and date on my Charge 2
time needs to be changed on my fitbit charge 2
15 REPLIES 15
My date and time is wrong ~ how do I reset this?
Reset time and date
Hey guys, @Treads1@pusskin and @cherylj623! I hope you are doin' fine! In order to reset the time and the date on your Charge 2, let me suggest you the following:
- Make sure that you have the correct timezone settings on your account
- Verify that you have the latest version of the Fitbit app, either on your iOS or Android phones
- Restart your Charge 2
- Reboot the Bluetooth on your phone
- Log out/log in to your Fitbit account to refresh the app
- Force sync your Charge 2
By the way guys, I moved your posts to the correct board, Charge 2, so you can better assistance.
Let me know if that works!
Heydy | Community Moderator, Fitbit
howHi just want to know how to change time and date on fitbit charge 2
Hey @Laurae123, welcome aboard! If you'd like to change the time and date on your Charge 2, I suggest you to take a look at the information in this help article: How do I change the time on my Fitbit device?
Let me know how it goes!
I cannot login to reset time and date as it showing that the username is alredy used
Hey @Madhukarshinde, welcome aboard! Have you made sure that you have entered your correct e-mail address and password? Also I'd like to you to try to reset your password if you still can't log in. In addition, please try to log into your Fitbit account but using a computer, and let me know if you get the same error.
I'll be around!
How do I set time and date on my Fitbit?
Hey @Exercise5, let me give you a warm welcome to the Community! In order to set the time and date on your Fitbit device, remember that you have to make sure that the timezone settings are correct and sync your Fitbit, so it will take the time from the device you are using to sync. For further help, please take a look at this article: How do I change the time on my Fitbit device?
Hope that helps!
I haven’t worn my Fitbit charge 2 for some time.  How do I reset the date and time ?
I sync my phone to my Charge 2, but the time does not update.  BTW the date and time on my phone is correct
How do I change time and date on my fitbit charge
Need to change date and time
how to fix date abnd tome
Try connecting your device via Bluetooth and getting the Fitbit app on a windows 10 computer.  I found this synced perfectly when my date and time was way off on the Fitbit.  On the first sync, it updated the date and time on my Fitbit.  Then I could finally sync the Fitbit to my phone.  The Android OS and many others have trouble communicating with devices whose system date and time are out of whack.
