05-25-2020
18:00
16:17
05-25-2020
18:00
16:17
05-26-2020 07:54
05-26-2020 07:54
You can change the brightness through the settings menu on the Charge 4.
See pages 18,19 of the user manual @Hubidiah
05-26-2020 07:54
05-26-2020 07:54
05-27-2020 09:31
05-27-2020 09:31
Welcome to the Community, @Hubidiah and @Rich_Laue, thanks for the input.
I was able to see here that our friend @Rich_Laue provided some instructions regarding your brightness inquiry. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out.
06-17-2020 15:34
06-17-2020 15:34
That worked great. Thanks
06-18-2020 06:18
06-18-2020 06:18
It's great to welcome you, @Halwg51.
I am glad to hear that the instructions provided by our friend worked. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up! 🙂
01-21-2021 06:44
01-21-2021 06:44
Where is the settings app? I can't find it
01-23-2021 12:02
01-23-2021 12:02
Hey @Vbabot73, welcome to the Forums.
Regarding your inquiry, the settings that are on your Charge 4. For more information, check the article: How do I navigate my Fitbit device?.
Let me know if you need anything else.
04-23-2021 15:06 - edited 04-23-2021 15:09
I went into settings changed from normal, which was not bright enough to the only other options which are auto and dark. I chose auto and now I can barely see the screen at all. Isn't there a bright option?
02-02-2022 16:49
02-02-2022 16:49
did not work for me. Instructions written in a different language
