Add Pilates to the Charge 5
ANSWERED
My charge 4 recognized Pilates- which is my daily exercise. Sadly my charge 5 does not. Can I change that?
Moderator edit:  updated subject for clarity
1 BEST ANSWER
Accepted Solutions
Hello @JudyFlo
You can set an Exercise Shortcut for Pilates on your Charge 5 and then press Start and Stop to record it in real time.
From the Today Screen in the App on your phone, tap your profile picture, then Charge 5.  Tap Exercise Shortcuts and choose one to delete by swiping left on it.  Then go to + Exercise Shortcut and choose Pilates.  Sync your Charge 5 and check it's turned up under Exercise.
I hope that helps.
3 REPLIES 3
Hello @JudyFlo
I hope that helps.
Thank you! I will try that!
Sent from my iPhone
Thank you so much for these easy to understand steps to add Yoga and Pilates to my Fitbit Charge 5.
