12-19-2021 20:45
12-19-2021 20:45
It would be nice to have aerial arts (such as Lyra, trapeze, silk, hammock, cord lisse) added to the Fitbit app. You can’t wear a tracker while performing them. However it would be nice to be able to track them manually.
Best Answer12-21-2021 04:21 - edited 12-21-2021 04:24
@Aliciaridout You can log it manually, but you won't be able to log it as Lyra, trapeze, etc. Personally, I would log it as "yoga". Here are a few screenshots of how I did it.
Best Answer12-21-2021 01:20
12-21-2021 01:20
Hello @Aliciaridout
I was really surprised to check and see that none of your exercises were listed. I guess they are slightly niche so that could be why.
It would probably be a good idea to either make a suggestion or add your comment and vote to an existing suggestion.
You could follow this link:
If you look in the search box, you can see if there's something similar. If there isn't, you could post your suggestion there where it has more chance of being seen by the developers.
Good luck!
