12-20-2021 21:31
12-20-2021 21:31
Please make a Charge 5 clock face with a large step counter on it!
12-21-2021 01:05 - edited 12-21-2021 01:10
Hello @DelPi
The Ice Cream clock face might be a good one for you.
The only real problem with it is the deliberately 'out of focus' style. But it displays the steps in a really big way.
You can get it by tapping your profile picture on the Today screen in the App on your phone. Then Charge 5, tap. Tap on Gallery, tap on Clocks at the top, then you can look at the clock faces and choose one you like.
Install, then sync your Charge 5.
I hope that helps to solve your problem.
Edited to add: Sorry I might have misread the screenshot. That might be the time, not the number of steps! In which case, the ring is showing how far along your progress is.
If you check this link you can see if someone has made a similar suggestion and vote for it. If not, you could make you own suggestion.
12-21-2021 01:37
12-21-2021 01:37
12-21-2021 01:39
12-21-2021 01:39
Thanks for your reply Wibby but the digits are clock digits not steps.
12-21-2021 02:03
12-21-2021 02:03
Yes, @DelPi . I edited my post when I realized and added more at the end including a link to making a suggestion yourself.
If you can, try the link and make a suggestion.
