09-28-2025
18:11
09:21
CrisVillaFitbit
09-28-2025
18:11
09:21
CrisVillaFitbit
I've had this fitbit for years now, like maybe since 2020 to 2021 at least. It's starting to really break down. Registers my heartrate at much higher than it is, doesn't register my sleep, doesn't show steps on my graph. Is there a good replacement based on my main goals? Mainly steps, zones, heartrate, and sleep. I'm so tired of using it and after a week, it stops working and I have to leave it be for a few days.
Moderator edit: edited title to clarity.
Hello and welcome to the Fitbit Community, @t1inama.
Thanks for letting us know your situation with the Charge 5 tracking your heart rate, sleep and steps more than it is, I can help you checking what is going on and do as much as I can to improve the situation. Can you let me know how you able to actually confirm it is tracking more that it is, please? Have you tried restarting your Charge 5 and check if both the app and Charge 5 are updated?
And, in regards to a good replacement, if you really want to upgrade, I recommend you to upgrade to the Charge 6, you can check the specs of it here.
