Auto-Detect Run Notification (Charge 5)
Charge 5's Auto-Detect Run feature is desirable, but it always prompts me to record the run by vibrating every thirty seconds.
I'm trying to have it be the case that it detects and records the run (GPS too) without vibrating/notifying me of anything (I don't want to look at it, and the vibrations are annoying). Is there a way for it to Auto-Detect and record without user-input (including start/finish buttons)?
1 REPLY 1
Hello @Y-Kayden and welcome to the Community.  I’m sorry, but if you want your run tracked with GPS, you must interact with your device.  If you know you want to track it, I think you should use the Exercise app from the start.  The Run Detect can take several minutes to recognize the run, then more time to connect the GPS.  The map starts from that connection on.  Just a thought.
Laurie | Maryland
