Hello! I am trying to get some guidance with the auto-pause feature. Whenever I try to start a bicycle ride or a run before I start the workout I check under settings, and only I see heart zone notifications and always-on display but not auto-pause. Auto-pause was a big reason why I upgraded to this watch. Any guidance would be appreciated. Thanks
Hello @bhende04
The setting for Auto Pause is on your Tracker. Press Start for the activity, then scroll up and you should find it. It’s after Set A Goal, Heart Zone, GPS etc. Just tap it to turn it on. It should remember each time but might switch itself off if there’s a firmware update, so always check after that.
I just checked and it’s available for Run but not Bike.
I searched and found that it’s a feature many people have requested for previous Charges. It might be an idea to make a new Feature Suggestion for it to be added to ALL trackers rather than just the Charge 5, so that people can find it and vote for it. Here’s a link to Feature Suggestions:
I hope that helps a bit.
