06-11-2022 04:50
06-11-2022 04:50
It seems to me it should have gone down by now with weight loss. Am I supposed to recalculate it and enter manually?
06-11-2022 05:40
06-11-2022 05:40
Hello @seapiatone and welcome to the Community. I apologize if I am misreading your question. You posted this in the Charge 5 forum, but the Charge 5 doesn't show weight as part of the Today stats. Are you asking about weight on the mobile app? Are you using a Fitbit scale or another scale that syncs with the Fitbit app?
Laurie | Maryland
06-12-2022 08:50
06-12-2022 08:50
Hi @LZeeW ! Thank you for your response! I see what you mean and believe I was thinking the issue was with the device itself, buy my issue is more with the mobile app and the weight tracker. I don't have a smart scale but just entering the weight manually. Do you have any suggestions?
06-12-2022 09:42
06-12-2022 09:42
@seapiatone I use a Fitbit Aria 2 scale, which shows BMI on the scale and transfers it to the mobile app. The mobile app has several graphs in the weight section. I have four graphs accessible by swiping: Weight Trends, Lean vs Fat, Body Fat % and Current BMI. You might or might not have all four graphs.
I did a little test. I was out of town a while ago. I manually entered a weight and logged for a day when I wasn't home. I intentionally entered an incorrect weight. My BMI graph showed the calculated BMI for that weight on that day.
I also want to add that the Fitbit Aria 2 (which measure body fat percent) is discontinued. Fitbit calls the Aria Air a smart scale. I don't consider it a smart scale. It reports weight and BMI. There are other brands of smart scales that will sync with the Fitbit app.
Laurie | Maryland
