Can I replace my Charge 5 battery?
ANSWERED
Where can i replace my fitbit charhe 5 battery?
1 BEST ANSWER
Accepted Solutions
Hi there, @TuyenTran. Welcome to the Fitbit Community Forums.
Please note that the battery on your Charge 5 is not replaceable nor interchanged. We as Fitbit do not do it or suggest to do it as it could permanently damage your watch.
Keep in mind that your Charge 5 was designed to last 7+ days, but this also depends on how frequently you use all the features of your watch. Said that, I recommend charging your Fitbit watch with a USB port from a computer or a UL-certified outlet into the wall and then turn off all the features that you don’t use that much.
If you have charging issues, please check the help article shared by @Talahthas. On the other hand, if the battery is draining, see Can I extend my Fitbit device's battery life?
If none of the above seems to work, please follow @Talahthas's advice and chat with us online or give us a call. Click here to get connected.
2 REPLIES 2
Welcome to the Fitbit community, @TuyenTran!
If you're having issues with your Charge 5's battery, please contact Fitbit support to get assistance:
Fitbit Support Contact
Before doing so, however, please have a look here to see if this might be of any help for you:
Why isn't my Fitbit device's battery charging? :
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2
