02-05-2024 10:08
02-05-2024 10:08
Mostly posting this to possibly support others that are in the same situation. I've had 3 charge 5s:
Currently, I'm lucky if I can get through a day without the battery dying, and that's not using it for any activity tracking - if I do that, it dies even faster. I've noticed that a lot of people are having batter issues after the latest firmware update, not sure if that has made my issue worse or not.
I really like this watch...when it works. In my experience, is seems to last about a year and then battery issues start to crop up and the watch becomes useless. My experience indicates there could be some kind of battery/hardware issue that contributes to it's death after about a year and I wouldn't recommend that anyone buy this watch (yes, the Charge 6 has replaced it), and I wouldn't recommend that anyone buy the Charge 6 either, since it's basically the same watch (from what I've read). Software updates could play into the battery life as well, but regardless, I didn't purchase this watch to have to deal with all of these headaches. One of the main reasons I purchased it was for the decent battery life, and that's no longer working correctly. I should be able to get years worth of life out of a watch like this. I have a cheap $30 "smart" watch I purchased 4 or 5 years ago and it still works fine, battery life is great, so if they can make it work for $30, they should be able to make it work at the Charge 5 price point as well.
It's time to say good-by to Fitbit, I'm not going to buy a new watch every year, even if they do offer me a discount for a "replacement". I don't want to have to put up with the headaches and hassles after about a year...if it lasts that long. I'm looking elsewhere for my next fitness tracker.
P.S. If, for some miraculous reason, battery life were to improve, or be fixed by a software update or some other "trick", I'd be happy to change my opinion, but I don't see that happening, this watch has already struck out 3 times for me.
02-05-2024 10:26
02-05-2024 10:26
I'm having the same issues with my fitbit Charge 5. I am on the fourth watch, and it stopped charging all of a sudden. None of the watches were able to last more than a year and some broke after less than 6 months. I'm having the same issues you described. At this point, I'm shopping for another brand,
02-05-2024 10:30
02-05-2024 10:30
I have the original Charge (I think I purchased it in 2016 or 2017) and luckily it's still working... seems like there's some quality issues with newer versions of the Charge.
Best Answer02-05-2024 12:10
02-05-2024 12:10
The Charge 5 was my initial foray into the Fitbit ecosystem, and I was excited - based on reviews of previous versions. I was hoping it would last for at least 3 years. Alas...
